KB85034
Published: September 9, 2015
PAC Control I/O Unit commands do not support SNAP-PAC-R1-B
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4c and higher
In PAC Control, when you choose an I/O Unit command, you do not see SNAP-PAC-R1-B as a choice in the list of I/O units supported.
NOTE: The SNAP-PAC-R1-B was first supported in version R3.0c. Reverting to an earlier version of PAC Control will not resolve the issue.
