KB85020
Published: November 30, 2015
PAC Control: Scaled unit incorrectly appears in Actual Unit field
PAC Control Basic
PAC Control Professional
Version affected: R9.4e, but possibly affects lower versions
In PAC Control's Edit Analog Point dialog box, the Scaling: Actual Units field incorrectly shows the units you entered. It should show the default units.
Simply ignore the incorrect field. It's just a label and it doesn't affect the scaling values.
