KB84979
Published: September 13, 2016
-39 error (Timeout on Receive) should not close UDP communication handles
Versions affected: All firmware versions
Problem is fixed in version: FW R9.5e
Note: This issue affects only UDP communication handles.
If a UDP communication handle experiences a -39 error (that is, the connection times out while receiving data), the comm handle closes. However, UDP comm handles should remain open, even after receiving a -39 error.
Before attempting to do a receive, add a "Get Number of Characters Waiting" command in your strategy to check that data is waiting to be received.
