KB84921
Published: January 5, 2016
PAC Control: Unable to see all algorithm data in the View PID Loop (scanning) dialog box
PAC Control Basic
PAC Control Professional
Problem was discovered in version: R9.4e (May also affect lower versions)
Depending on your computer's display settings, you may not be able to see all of the data on the Algorithm tab when viewing a PID loop in PAC Control Debug mode.
You may be able to work around this issue by:
  • Adjusting your computer's display settings.
  • Holding down the CTRL key and rotating the wheel button on your computer's mouse to resize the data.
