KB84898
Published: December 10, 2015
PAC Control: Handshake failure sending email to SMTP server using SSL certificate with specific algorithm
SNAP-PAC-S1-FM
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R9.4b and lower
When a SNAP PAC controller tries to send an email to an SMTP server using TLS, the controller reports a handshake failure and the email is not sent. This issue occurs only if the server uses a root certificate signed with a SHA256RSA or SHA384RSA algorithm.
This issue may occur with two commands in PAC Control: Send Email and Send Email with Attachments.
This issue does not affect SoftPAC.
