KB84896
Published: July 28, 2015
E2 brain boards: Reset to defaults does not reset gain
E2
Problem affects versions: Firmware R1.1b and higher
On an E2 brain board, when you execute the Reset To Defaults command (either in PAC Manager or by writing to OptoMMP address 0xF0380000, Operation Code 2), all values are reset except the gain of any analog inputs.
Manually reset the gain to 1.0.
