KB84893
Published: July 28, 2015
PAC Display alarm email does not show alarm value; displays "f" instead
Problem affects versions: R9.0a and higher
If an alarm email is received from PAC Display, you may see "Value=f" in the email instead of the actual numeric value (for example, Value=1.5).
This issue occurs only when the value is a float.
