KB84892
Published: July 28, 2015
PAC Display alarm does not trigger email
Problem affects versions: R9.0a and higher
In PAC Display Configurator, if you configure an alarm to send emails, the alarm occurs in Runtime but the email may not be sent.
Normally the email is sent, but if the alarm setpoint is operator adjustable and the operator changes the setpoint into the alarm range, this issue may occur.
Make sure operators do not adjust alarm setpoints to a value that will trigger an alarm.
