KB84885
Published: December 10, 2015
Mistic I/O is not enabled after watchdog timeout
SNAP-PAC-S1-FM
Problem affects versions: Firmware R9.4a and higher
If the mistic I/O is set up with a watchdog enabled, and if that watchdog times out, attempts to enable the I/O will fail unless the I/O is power cycled to clear the watchdog error.
Cycle power to the I/O unit. (It is not necessary to cycle power to the controller.)
Opto 22has resolved this issue.
