KB84878
Published: June 26, 2015
PAC Display Runtime may crash if Alarm Log files contain a mix of pre-R9.4a and post-R9.4a data
Problem affects versions: R9.4a and higher
When PAC Display Runtime starts, if the "Reload History Alarms" option is set and the alarm log file has data from PAC Display 9.3 or previous as well as 9.4 or newer, PAC Display will crash.
Uncheck the "Reload History Alarms" option.
