KB84864
Published: March 7, 2016
In groov notification editor, editing an array tag defaults to index 0, regardless of the index chosen
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a - R3.0e
Problem is fixed in version: R3.1a
When you're editing an event notification message, the tag chooser does not reflect the array index you chose, if the tag you're editing is an array tag.
For example, if the notification message shows “< Tag Name[3] >” for an array tag using index 3, the tag chooser would incorrectly show array index 0 when you edit that tag.
Choose the array number again.
