KB84861
Published: June 18, 2015
Firefox will not allow copying individual text from groov Event Message logs
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a
Problem is fixed in version: R3.0b
If you're using groov in Firefox, when you click an individual event in the Event Message logs, all the text of the event is highlighted. You cannot copy just a portion of the event text.
This issue affects Firefox only.
Use a different web browser (not Firefox).
