KB84849
Published: June 16, 2015
groov Build: Cannot use Ctrl-V hotkey to paste gadgets between pages
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a
Problem is fixed in version: R3.0b
In groov Build the paste hotkey, Ctrl-V, does not work to paste gadgets copied or cut from one page into another page.
To paste a copied or cut gadget to a different page:
  • Right-click in the page where you want to gadget to be and choose paste from the popup menu.
--OR--
  • Choose Paste from the Edit menu.
