KB84829
Published: June 16, 2015
groov Build: Cannot change line type in the Trend gadget
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a
Problem is fixed in version: R3.0b
In groov Build you should be able to choose a different line type for a Trend gadget by clicking the Configure Data Sources button in the Trend Properties area of the workspace.
However, clicking the down arrow for Line Type does not open the dropdown menu and allow you to choose.
Click the very top of the box that shows "Line" to open the dropdown menu.
