KB84820
Published: June 26, 2015
When Chrome browser is maximized, groov gadgets may not be properly resized
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a and higher
Problem is fixed in version: R3.2a
If you are using groov Build in Chrome and the browser window is fully maximized for your monitor, when you try to re-size gadgets they may jump or flicker.
Don't maximize the Chrome browser window.
Or use a different browser (Firefox, Internet Explorer 10 or above, Safari).
