KB84816
Published: June 16, 2015
IE and Firefox do not display the Event Status Viewer properly from groov Build
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a
Problem is fixed in version: R3.0b
This issue occurs only when using the Internet Explorer (IE) or Firefox browsers.
When you're in groov Build and click the bell icon (upper right) to see the Event Status Viewer, a new viewer window appears, but the Build window changes to display only the text "Object".
Use Chrome rather than IE or Firefox.
Or navigate back to groov Build by typing in the URL of the groov box plus /#build
