KB84815
Published: June 26, 2015
Z-order with groov gadgets is inconsistent
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: All versions
In groov Build, moving gadgets from front to back and vice versa (changing Z-order) is inconsistent. Examples: sometimes if you send a gadget to the back (behind another gadget) and then try to bring it to the front, it doesn't move. Sometimes a gadget's border still appears after moving it to the back, or a trend gadget does not follow normal Z-order patterns.
