KB84803
Published: June 5, 2015
PAC Display Runtime: non-sequentially configured tables may show incorrect data
Problem affects: All versions
In PAC Display when you're configuring a table object, if you configure the tables out of order, data may show up shifted to the wrong column.
Make sure you configure the tables in order.
