KB84794
Published: May 27, 2015
Event triggers using decimal values are not rounded off in groov View
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects version: R3.0a
R3.0b
In groov Build, if you use a decimal value as an event trigger, the value is a floating point that appears in groov View as the nearest possible number; it does not round for clarity.
