KB84785
Published: May 27, 2015
groov: Text for some gadgets disappears unless you click inside the properties panel
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: All versions
Text you enter in some gadgets' properties panels won't be saved unless you click inside the properties panel after entering it. If you click outside the properties panel after adding the text, the text will disappear.
For example, if you enter a title for the axis in a trend gadget, you must then click inside the trend gadget's properties panel so that the title will be applied.
After entering text in a gadget's properties panel, click inside the properties panel before doing anything else.
