KB84784
Published: May 27, 2015
Boundaries for gadgets in groov Build may not line up with workspace area
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: All versions
In groov Build, if you try to extend a trend gadget from top to bottom to fill the workspace area, the trend does not go all the way to the bottom of the workspace.
However, if you move the trend gadget so that its lower boundary meets the lower boundary of the workspace and then extend it up, it will fill the space.
Move the gadget to the bottom of the workspace and and extend it upward.
