KB84762
Published: May 27, 2015
PAC Display Configurator may crash when configuring a "Text in from controller" dynamic attribute
Problem affects versions: 9.4a and higher
In PAC Display Configurator, if you configure a dynamic attribute for "Text in from controller" as Discrete, but you forget to fill in the Discrete On and/or Off fields, Configurator may crash.
If you forget to fill in the Discrete On or Off fields, clear the dynamic attribute before re-configuring it.
