KB84731
Published: December 10, 2015
SNAP PAC controller connection to secure server may fail
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
Problem affects: All versions
When a SNAP PAC controller tries to connect to a secure server (with SSL or TLS encryption), if the secure server has a certificate name that differs from the DNS name required to connect to the server, then you may get a -2104 error.
Note: A more common cause of a -2104 error is a missing or incorrect certificate, so check to make sure the correct certificate is installed on the SNAP PAC controller.
The following PAC Control commands could be affected:
  • HTTP Get
  • HTTP Post From String Table
  • Send Email
  • Send Email With Attachments
