KB84700
Published: April 24, 2015
Invalid Address message when modifying a controller definition
Versions affected: PAC Control R9.4a or newer
When a controller definition is improperly modified and then the OK button is pressed, the message "Invalid IP Address" will be displayed.
Change System Type to Redundant Controller and type 0.0.0.0 in the "Controller 2 address" and "Arbiter address" fields. Then switch the System Type back to Standard.
Opto 22 has resolved this issue and include the fix in an upcoming release.
