KB84695
Published: October 8, 2015
After selecting and unselecting gadgets in groov Build, the arrow keys no longer work as expected.
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: groov App, all versions
In groov Build, after you select and unselect a few gadgets, you can no longer move the gadgets with the arrow keys.
Reselect the gadgets you want and try again.
