KB84680
Published: April 17, 2015
Windows Exception Fault when inspecting a point in PAC Manager
PAC Manager
Problem affects versions: R9.4c
When inspecting an analog point in PAC Manager (Tools > Inspect > Analog Point), if you click the “More Info” link, you receive a Windows Exception Fault.
Do not click the “More Info” link in the Analog Point Inspect window.
-or-
It may be possible to go to Control Panel > System > Advanced system settings and click the Settings button in the Performance group box. In the Data Execution Prevention Tab, add PAC Manager to the list of programs to not check for DEP.
