KB84669
Published: April 17, 2015
groov logo flashes when switching from groov Build to groov View even though logo is turned off
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3c and lower
Problem is fixed in version: R3.0a
Even if the logo for groov is turned off in project settings in groov Build, when you switch from Build to groov View, you see the logo for a split second.
