KB84657
Published: April 2, 2015
PAC Control command UnpackString does not compile in OptoScript block
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4a - R9.4c
Problem is fixed in version: R9.4d
If you use the Unpack String command in an OptoScript block, the block won't compile.
