KB84647
Published: December 2, 2015
PAC Display Runtime may crash when using PID button
Versions affected: R9.3a to R9.4f
Problem is fixed in version: R9.4g
Clicking on the Auto/Man button or entering a new value in one of the edit fields and pressing Enter may cause PAC Display Runtime to crash.
This only happens if no other writes to output dynamic attributes have already occurred. So, if you did a Send Value, etc. on a graphic, then launched the PID Dialog from the PID button, this crash would not happen.
Execute some other output dynamic attribute first, not related to the PID button.
