KB84588
Published: December 10, 2015
Spaces in file COM handle connect string make files inaccessible
SNAP-PAC-R1-B
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
SOFTPAC
Versions affected: R9.4b and earlier
Spaces in the connect string for creating a file with a COM handle may make the file inaccessible. Any attempt to access the file via FTP will result in a "critical file transfer error."
For example:
This communication handle is incorrect. It shows a space in the string after the comma:
file:w, test.txt
This communication handle is correct:
file:w,test.txt
Spaces inside a file name are permitted. For example, file:w,test 01.txt
Make sure your connection string has no extraneous spaces.
