KB84552
Published: March 12, 2015
Windows Exception Fault when inspecting a point in PAC Control
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.3 and R9.4
When inspecting a point in PAC Control Debug mode, if you expand the dialog box and click the “More Info” link, you receive a Windows Exception Fault.
Do not click the “More Info” link on the expanded point inspection dialog box.
-or-
It may be possible to go to Control Panel > System > Advanced system settings and click the Settings button in the Performance group box. In the Data Execution Prevention Tab, add PAC Control to the list of programs to not check for DEP.
