KB84551
Published: January 4, 2016
PAC Control: Clearing I/O unit's configuration may cause reset
PAC Control Basic
PAC Control Professional
Versions affected: R9.4b and lower
Problem is fixed in version: R9.4c
When inspecting an I/O unit in PAC Control Debug mode, if you clear its configuration (by clicking Clear on the Information tab of the Inspect I/O Unit dialog box), the I/O unit will also be rebooted.
If the I/O unit is the local I/O of an R-series controller/brain, clicking Clear will reboot both the controller and the I/O unit.
