KB84543
Published: November 25, 2015
Invalid values on x86 and AMD64-based computers with PAC-DEV-OPTOMMP-DOTNET SDK
.NET OptoMMP Software Development Kit for SNAP PAC
Problem affects versions: R3.0.0.0 through R3.0.2.0
Problem is fixed in version: R3.0.3.0
If you are using Opto 22's .NET OptoMMP Software Development Kit for SNAP PAC with an x86 or AMD64-based computer, you may see invalid values with the method ReadOptionallyClearAnalogMaxMin4096(). This is a byte order issue.
