KB84524
Published: February 18, 2015
Unused points on E1/E2 brains can be read and written to
E1
E2
Problem affects: All versions
The E1 and E2 brain boards use only point 0 of each module on the rack, but points 1-3 can also be read or written to. Reading these points will always result in OFF or 0. Writing to these points has no effect on the E1/E2.
Ignore points 1-3.
