KB84519
Published: December 10, 2015
Revision: 5.0
PAC Control commands that use SSL/TLS may return HTTP Status (like 202) in the "Put Status In" variable
Versions affected: PAC firmware R9.1a through R9.5d
Problem is fixed in version: FW R9.5e
In some cases, email or HTTP post commands using SSL/TLS may return an HTTP status 202 in the "Put Status In" variable, instead of putting it in the appropriate "Put HTTP Status In" variable.
Note: This issue was partially resolved in PAC firmware R9.4c and higher.
Additional firmware changes were released in PAC Firmware R9.5e.
