KB84453
Published: December 2, 2015
PAC Control debugger not in sync with redundant system that has switched to the backup
PAC Control Basic
PAC Control Professional
Problem affects versions: R9.4a - R9.4b
Problem is fixed in version: R9.4c
If you are using PAC Control with a redundant controller system and you are in the PAC Control debugger, if the redundant system has switched to the backup, communication to I/O units will not work and will be disabled.
