KB84411
Published: January 19, 2015
PAC Display: Find Tag returns only the first letter of the object location
Problem affects versions: R9.4a - R9.4d
Problem is fixed in version: R9.4e
In PAC Display Configurator, if you choose View > Find Tags and set it to Show Report, the report appears and displays the locations where the tag was found. However, window names or other container names (such as Historic Data Logs) are only shown by their first letter.
If this issue occurs, you can usually figure out where the tag is by searching all windows that start with the displayed letter.
