KB84404
Published: January 19, 2015
Some OptoMMP commands to E1/E2 brain boards do not return appropriate error
E1
E2
Problem affects versions: Firmware R1.1e and lower
Problem is fixed in version: Firmware R1.2a
If you are using a custom OptoMMP program with an E1 or E2 brain board, and you send a command other than one of the following, you will receive no response:
  • Write Quadlet Request
  • Write Block Request
  • Read Quadlet Request
  • Read Block Request
Use only tcodes 0, 1, 4, or 5 (the four commands listed above) with the E1 or E2.
