KB84396
Published: August 13, 2015
OptoMMP addresses not used by E1/E2 brains do not return an "Invalid Address" error
E1
E2
Problem affects: Firmware R1.1e and lower
Problem is fixed in version: Firmware R1.2a
If you read or write a value to an address that is within a valid MemMap area but not implemented on the E1/E2, you do not receive an error message. An E005 (invalid memory address or invalid data for the memory address) error should be returned when accessing these addresses.
