KB84368
Published: November 25, 2015
groov Graph gadget may have trouble showing min/max 32-bit or 64-bit float values
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects: All versions
In groov View, you may see incorrect data on a graph for a maximum positive or negative 32-bit or 64-bit floating point number. (The Y-axis may show the wrong value range, or the Y-axis range labels may consume a large portion of the graph.)
If you expect large floating point values, it may help to make the graph very wide.
