KB84314
Published: December 1, 2015
Downgrading to a lower-numbered version of PAC Project does not downgrade OptoOPCServer
PAC Project Professional
OptoOPCServer
Versions affected: R9.4003 and lower
Problem is fixed in version: R9.4004
If you uninstall PAC Project and then install a lower-numbered version, the installation process installs the lower versions of all PAC Project components except OptoOPCServer. Instead, the installation leaves your current version of OptoOPCServer installed.
