KB84297
Published: December 18, 2014
groov: CA-signed SSL certificate generated by groov SSL certificate utility cannot be installed
groov Server for Windows
groov Server for Windows for SNAP PAC only
Problem affects: groov App R2.3c and lower
Problem is fixed in version: groov App R3.0a
If you use groov's SSL Certificate utility to create a private key and then try to install a CA-signed SSL certificate, the private key file cannot be found.
