KB84295
Published: November 25, 2015
Premature return of "-10" error in PAC-DEV-OPTOMMP-DOTNET SDK
.NET OptoMMP Software Development Kit for SNAP PAC
Problem affects versions: R3.0.0.0 through R3.0.0.2
Problem is fixed in version: R3.0.2.0
If you're using Opto 22's .NET OptoMMP Software Development Kit for SNAP PAC and call the methods ReadBrainDiagnosticInformation() or Open(), you may receive an immediate “-10” error.
This issue occurs when the memory map address you are trying to read or open does not exist for that product type and firmware.
