KB84293
Published: December 19, 2014
OptoDataLink crashes on data change with error code 80070006
OptoDataLink
Problem affects: All versions installed with OptoOPCServer R9.4
Problem is fixed in version: OptoDataLink R9.4d
In OptoDataLink, error queues are filled with error code 80070006 on all OPC operations.
This issue may occur with any version of OptoDataLink, but only if OptoOPCServer R9.4a or higher is also installed.
Revert to a version of OptoOPCServer lower than R9.4a.
