KB84278
Published: December 10, 2014
File "find" COM handle command may return erroneous results
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects: Firmware R9.4a
Problem is fixed in version: Firmware R9.4b
When using the "Send Communication Handle Command" to find a string within a file, if the string to find is passed as a string variable, the return result may or may not be valid.
Use a string literal as the string to find.
