KB84276
Published: December 10, 2014
PAC Control "Convert IP Address String to Integer 32" command may return an invalid value
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.4b and lower
Problem is fixed in version: Firmware R9.5a
If you are using PAC Control's "Convert IP Address String to Integer 32" command and you pass an empty or invalid IP address string, the return result is undefined.
This command expects the source string to always be in an nn.nn.nn.nn form.
Make sure the source string is correct before calling this command.
