KB84214
Published: December 2, 2015
Edit > Replace feature in PAC Display Configurator does not work for table objects when Search For is set to Refresh Group
Problem was discovered in version: R9.3a
Problem is fixed in version: R9.4e
The Edit > Replace feature does not work for table objects when "Search For" is set to Refresh Group.
Manually edit each table tag in order to change the refresh group.
