KB84193
Published: December 10, 2014
Reverting to an earlier version of groov may leave "groov is Loading..." message on screen indefinitely
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: All versions R1.0c and higher
When you go back from a newer version of groov to an older version, groov may fail to load and the "groov is Loading..." message may remain on the screen.
This appears to be an issue with the browser cache.
Use shift + F5 to reload groov and ignore cached content, or open a new browser tab.
