KB84164
Published: October 31, 2014
PAC Display Runtime may crash if a window is configured to close and there are reads / writes in progress
Versions affected: R9.0a – R9.4b
Problem is fixed in version: R9.4c
If a window is configured to close and it contains buttons configured with several operator-driven attributes such as Send Value, Send Discrete, Toggle Discrete, and Send String, if the other operations have not completed by the time the window closes, Runtime will crash.
Use separate buttons for the send attributes, or close the window manually after all sends are finished.
