KB84163
Published: October 31, 2014
'Text In from Control Engine' Discrete On and Off text fields only display first character
Versions affected: R9.4a and R9.4b
Problem is fixed in version: R9.4c
When a dynamic attribute is configured to be "Text In from Control Engine" and it is set up by Discrete, the On and Off text data fields will only display the first character. In Configurator, this is seen only after saving, closing, and re-opening the project. The issue occurs when the project is loaded in either Configurator or Runtime.
